Lubricate Waste Valves
tslarson
Re: Lubricate Waste Valves
Post by tslarson » June 19th, 2016, 10:21 am
Looks like I just found my first project of the day. Great idea!
2009 Ford F150 CC FX4
Post by Houston Remodeler » June 15th, 2016, 9:15 pm
Good idea. Mine are getting sticky
Post by moallen » June 2nd, 2016, 8:31 pm
It's a good idea to lubricate the steel shaft attached to the handle of a waste valve to keep the shaft guide from wearing out. But that doesn't help much to lube the slide inside the valve. The slide gets hard to open and close, which puts stress on the valve. It's nearly impossible to lubricate the slide inside without taking the valve apart, which is no one's idea of fun.
I can't take credit for this idea but thought I'd pass it on. I drilled a 7/64" hole in the end of each of my waste valves and then tapped each for an 8-32 screw. I'm going to replace these screws with stainless steel ones as soon as possible.
Now I can lube the inside using a plastic extension on a can of silicon spray lubricant. I open and close the valve several times while spraying for about 5 seconds.
By the way, you should never use a petroleum based lube on plastic parts, for example WD-40. The plastic will eventually deteriorate. Rule of thumb - if it says flammable, don't use it. Only silicone spray or silicone grease is safe on plastic.
Silicone spray is also good for the sliding plate in a toilet.
