Radio DVD Replacement
Re: Radio DVD Replacement
Post by jcarlilesiu » May 31st, 2016, 5:43 pm
nice install.
Most car dashes that would be installed in are tight as well, so I am not sure why you would have an overheat issue.
Seems like a call to the manufacturer might be in order.
dianescraps
Post by dianescraps » May 31st, 2016, 2:31 am
We had a problem with a Furion DVD player on one of our first trips, it ate a DVD, and then would randomly turned on. After doing some research is seemed best to just replace it and move on. We are not the handiest of people but we found a unit on Amazon with a similar wiring set up and went with it. We picked up BOSS AUDIO BV8970B Single-DIN 7 inch Touchscreen DVD Player Installation went pretty easily, the only thing we will note about the replacement unit is it can overheat ( solved by not leaving radio on for the dogs when we are not in the camper) I think we will eventually figure out a way to get some more venting into that area
Picture of unit installed is attached.
Users browsing this forum: Bing [Bot] and 0 guests
