If you want to DIY replace, there are many many places to order from, including Amazon. Really good deals to be had. You will need to do research and measuring to determine exactly what you will need, may even need to talk to the factory support people. (awning factory)
If you want it to be replaced, find an RV repair person/company in your area.
When you say you want rails and all, it sort of complicates things. The designs change every few years. New may not exactly fit old. Usually there is a way to make things fit as closely as possible.
Star Stream awning
Re: Star Stream awning
Star Stream awning
Hello, I have a 2007 Star Stream 25 ft and the awning is tore up, were is a good place to get the whole awning from? Need the rails also. Thanks
- 20200314_161624.jpg (5.96 MiB) Viewed 3408 times
