Water pump won’t shut off -switch at panel off
Re: Water pump won’t shut off -switch at panel off
It was actually a 2nd switch, on the rear exterior. I didn’t know I had one. Somehow it was turned on.
Bad switch
That goes against logic .... the switch should cut power to the pump . Clearly that isn’t happening. Probably will need some troubleshooting and electrical work done. That’s my guess.
Hello,
I winterized my 289BHS today. And my water pump is running with the switch at the monitor panel off. If I pull the fuse it will shut off.
I drained the fresh water and water heater tanks. Used the pump to siphon rv antifreeze and ran all taps (hot and cold) untill antifreeze flowed through. Shut all taps, turned off the switch and could still hear the pump running. Any ideas?
