Adding Glass Cooktop Cover
waynescott5150
Re: Adding Glass Cooktop Cover
Post by waynescott5150 » May 19th, 2020, 11:19 pm
I wish I would've seen this shortly after you did this... these are $130 now (at least at Amazon) I did find these for about $90 but 3 week wait. Looks very good, I have the exact same 2 burner cook top in mine. Excellent job on this! My next project for sure.
Post by uct » February 7th, 2019, 10:09 pm
Nice
partsbob
Post by partsbob » February 7th, 2019, 3:18 pm
Yes, the cover is almost perfectly flush, as you’ll see in this photo. As far as holding up, the Suburban cooktop sits inside the recess of the cover frame with 4 screw holes exactly where the original screws held the cooktop to the counter. Very clean installation.
NC/VA Mountains
2019 Heartland Caliber 27RBDS
2018 Starcraft Satellite 17RB (SOLD)
TV: 2016 Ford F-150 Lariat 4WD EcoBoost
Post by uct » February 7th, 2019, 12:27 pm
Is the cooktop now flush with the counter top? What holds it up from below?
Post by kuba122 » February 7th, 2019, 12:08 pm
Very nicely done! What a great improvement to the counterspace. Thanks for the pictures.... that is definitely something I’d consider doing, as well. You made it look easy!
partsbob
Post by partsbob » February 6th, 2019, 4:30 pm
Though this was done to my 2018 Starcraft Satellite 17RB, it could benefit any camper needing more counter space, which the Satellite sorely needed. With the 17RB having the Suburban 2-burner cooktop and sink side-by-side, the only counter space is behind them and only large enough for a small coffeemaker and, even though I had already purchased a cutting board to fit over the cooktop for more usable space, I decided to install a “Suburban 2983A Glass Cooktop Cover” made specifically for this cooktop that I found available on Amazon for less than $80, after carefully measuring the space above AND BELOW the counter. I’ll warn you though, the packaging of the cover for shipping is very poor and it may take ordering 2-3 times to get one usable! My 1st order was severely bent all the way around the glass, so it was returned and the 2nd one came bent on a back corner, but I was able to straighten it well enough to use. I cut this one in close to the side wall on the right, so that when the cooktop is being used, the glass also keeps heat & splatters off the wall. Having seen these recessed burners on larger TT’s, I’m pleased to say the process went perfectly and the result is a game changer, as they say!
Granted, with the spacing instructions included with the cover for cutting out the countertop, I’m pretty handy doing my own work and had all the necessary tools, but I’m happy to share some pix of before & after.
NC/VA Mountains
