Drain hoses on front undercarriage
Re: Drain hoses on front undercarriage
Those are the low point drains. The handles to pull to drain are located under the bench seat inside the trailer, usually right next to the water pump.
Those look like over flow drains to me.
If I over fill my fresh water tank, it will start to over flow from the bottom.
I don't think they are low point drains as there aren't any valves, but maybe they are located inside.
Look like low point drains. Maybe the valves are inside the trailer directly above them? Might be behind a panel?
