Dish sat tv
rbrent
Re: Dish sat tv
Post by rbrent » May 22nd, 2018, 1:37 am
Well got to check out the suggestion. I found that the cables were in the wrong spot at the plate. A was B and B was A. Switched them around and now the Sat. works great! Thanks for the suggestion!
rbrent
Re: Dish sat tv
Post by rbrent » November 23rd, 2017, 3:29 pm
I do know that the booster should be off. I will look at the connections next time I have it out but it is put away for the winter here in Michigan. Thanks for the suggestion.
Re: Dish sat tv
Post by kuba122 » November 14th, 2017, 2:24 am
The cable is same for HD as for regular, the TV receiver is the only difference.
On my trailer they wired the back of the antenna booster incorrectly - might want to check that. I assume you know the booster green light must be off for sat to pass through to the TV from outside.
rbrent
Re: Dish sat tv
Post by rbrent » November 12th, 2017, 3:24 am
I have directv and in order to get sat Hd service I have to run a line thru the window directly to the box it does not work thru the outside cable/sat connection. I believe it is not set-up for HD probably just standard.
Re: Dish sat tv
Post by uct » October 1st, 2017, 11:41 am
Plate
Re: Dish sat tv
Post by uct » October 1st, 2017, 11:38 am
Thanks mine says the same. After some research it looks like I have to unscrew the short jumper from the plate under the tv near the booster and follow the printed directions on the plate .
Re: Dish sat tv
Post by kuba122 » October 1st, 2017, 2:05 am
Pretty sure you just use the external jack (mine says cable/Sat)
Dish sat tv
Post by uct » September 30th, 2017, 1:30 pm
I have dish network at home and just ordered a wally receiver and tripod ant. Kit. Can I just connect it to my external jack or do I need a dedicated sat jack
Users browsing this forum: No registered users and 24 guests
