Appliance, Etc Model Numbers
Re: Appliance, Etc Model Numbers
Thanks I hope you will post this.
Sounds like my 24rls has the same Furrion DVD player. It came with the same red-blue-green A/V aux-in cable you describe. I haven't tried it or needed it, because we have a factory installed TV connected to the normal yellow-red-white connections on the backside of the player. The TV has HDMI which my camera needs and 3.5mm audio which my wife's IPOD needs.
But getting back to the player's aux-in, from my experience there isn't any standard for 3.5mm A/V aux connectors, not just the colors themselves but also what band they connect to at the 3.5mm plug. The cable they supplied (red-blue-green) is normally a component (HD video) cable, not a composite A/V cable. Nonetheless, it will work just fine once we know which color is video and audio left/right. Some players with shared component/composite connections use green for video, blue for right audio and red for left audio. I'm going to send an email to Furrion support to see if they have a quick answer, otherwise I'll do some trial and error experimenting.
Thanks,we just purchased the same model. Do you know what the small connecter is that came with our paper work. It has a 3.5 mini plug on one end and 3 rca jacks on the other red green and blue.
I compiled a list of model numbers of appliances and other components in my Launch 24rls and thought I might as well post. Sometimes it's helpful when shopping for a new RV to see what's in a certain one - but always subject to change in the RV business.
2016 Starcraft Launch Ultra Lite 24rls
Furrion FUR-DV5100 Car Stereo
Continu-us TV CT-2820 28” Flat Screen TV
Shurflo Model 4008 RV Revolution By-Pass Pump
Winegard Roadstar Omnidirectional TV/FM Antenna
Winntec Model 6020 Automatic Change Over Regulator
Atwood 6 Gal. LP Water Heater Model G6A-8E
Atwood 19,000 BTU Furnace Model AFMD25121_A
High Point Microwave Oven Model EM925RCW
Coleman Airxcel 13,500 BTU Air Conditioner Model 48253C969
Atwood LP Gas Range Wedgewood Vision
Norcold Refrigerator Model N811 8 cu. Ft. 2-way
Ventline Range Hood Model PH22
WFCO Ultra III Power Center Model WF-8735P
Thetford RV Toilet AM5 Hi Hand, mcd. 31684, 150310-31684-0133
Lippert Schwintek In-Wall Slideout
Lippert Power Tongue Jack Model 1817941
Lippert Solera Power Awning (19’)
Lippert LED Awning Light Kit
Lippert ToyLoc Model 337118 (18’ Retractable Cable)
*Camco Eaz-Lift Elite Weight Distributing Hitch System Model 48054, Maximum Vertical Hitch Capacity 1,400 lbs, Maximum Gross Weight Rating 14,000 lbs
*Camco Eaz-Lift Sway Control Model 48380, One Bar (Right side mounted)
*Primus IQ Proportional Braking System Model 90160 (Tekonsha/Cequent)
*Danik Bumper Adapter Part #064025 2″ Hitch Receiver
*Allen Model 522RR 2-Bike Carrier
*Coleman Road Trip LXE Gas Barbecue Model 9949A
*Added components
*Added components
Users browsing this forum: No registered users and 19 guests
