New television connections
Re: New television connections
Post by kuba122 » August 24th, 2016, 11:18 pm
Just tested ... if you hook up your TV exactly as I told you to, it will be all good. Assuming the factory did everything the same ...
Post by moallen » August 24th, 2016, 5:28 pm
Mine is hooked up like this.
yellow wire - video OUT on Furrion radio/player to video IN on Sony TV
Red wire - audio OUT on Sony TV to audio IN on Furrion radio/player
White wire - audio OUT on Sony TV to audio IN on Furrion radio/player
When playing a DVD or listening to TV, the sound comes out my trailer speakers. Some TV's require going into the sound options and turning the TV's internal speakers off.
For what it's worth, I set the balance on my Furrion so all the sound comes out the speaker above my recliners. Helps a lot when the A/C comes on.
Post by kuba122 » August 24th, 2016, 11:52 am
Try this: White/Red to Audio Out on TV .... Yellow to AV1 V (video) on TV. I am assuming you have a Jensen JE3212LED TV. Let me know. I haven't tested mine, yet, I am just trying to help. I will try to test in my RV, if this doesn't work, when I get home from work, this evening ...
Post by kuba122 » August 24th, 2016, 1:23 am
For audio to play from the TV to the furrion, on the TV red and white would connect to "Audio Out" and on the furrion the red and white would connect to "Aux In" .... now, from the factory, I believe the red, white, yellow are for DVD to TV connection, the yellow, for sure is, I tested it in mine. Yellow would connect to video in on your TV. I never really tested the white/red .... I'll do so in the next few days, I'm curious, now ;)
Post by uct » August 23rd, 2016, 3:35 pm
Need to hook up my tv to my furrion dvd stereo so that i can plat tv sound through rv speakers like i used to. I did not think to write down where the red white and yellow were plugged. Tv is a jenson 32 and dvd stereo is furrion
Users browsing this forum: Google Adsense [Bot] and 12 guests
