Can't help you with routing the cable... Look for routes under the floor and up through cabinets, dressers, you just have to be creative.jcarlilesiu wrote:I need to mount another TV in the back bunk but can't figure out how to get the cable back there.
Plus I still haven't figured out if the HD antenna can have two different programs on different TVs at the same time if you use a splitter.
There may be wireless options for you to consider as well... (But a splitter should be ok.) When you are using a antenna the content you watch is determined by the tuner in the television, so you can watch different programs on different TVs.
When you have a dish, or a cable connection that requires a separate receiver to get programming, that is where you need a separate receiver for each TV you want to watch. Splitters might not work with a satellite setup.
