Not really sure what you're asking but the sinks, shower, and terlits should work normally. Just remember to;
1- Blow out all the air in the lines before turning on the hot water heater
2- Blow out all the air in the lines with the expectation of splashing water when the air gulps out
3- Connecting to the city water should not fill the fresh water tank. If it does, you have a check valve problem
4- A water filter before the trailer is a good idea to keep debris out of the water lines inside the trailer including the hot water heater.
City water connection
Re: City water connection
Hey gang... we picked up a 16RB about a month ago, our first RV. Have a water question...
When I connect the city water to the side of the trailer, is there a valve that needs to be moved so we'll be running off the hose?
Thanks!!
Thanks!!
Users browsing this forum: Google Adsense [Bot] and 12 guests
