I feel your pain brother.Dscan wrote: ↑September 30th, 2021, 12:17 pmNo problem. Also note when I originally installed this mount it was for a smaller tv that was sitting on the counter next to the sink. It was a way to regain that counter space. Alas the family wanted this larger one. Good thing I used a heavier duty mount to begin with. I was fine with the smaller tv but I was out voted as usual.
TV mount?
Re: TV mount?
Re: TV mount?
2013 Starcraft AR-ONE 15RB
Re: TV mount?
Thanks dscan this is very helpful.
Re: TV mount?
Here’s a couple more pics. As stated before can be moved into several angles and vantage points visible from most anywhere in the trailer.
- Facing toward back of trailer. Easy to watch if cooking or laying in the pop out tent looking into the trailer.
- 9AD225BA-057A-43F9-B07E-45A403D1BC3F.jpeg (17.1 KiB) Viewed 5736 times
- Angled toward dinette or bed.
- EA955C19-6C10-4CC9-893F-00D6DFE9C446.jpeg (19.15 KiB) Viewed 5736 times
- Facing the bench seat.
- 51408C8E-66B3-40BA-8EF0-78435B8239A7.jpeg (13.85 KiB) Viewed 5736 times
Re: TV mount?
Here’s what I did. I placed a tv wall mount on the right side of the cabinet just to the left of the air conditioner. I placed a piece of 2x4 behind the indent where the wood is thinner and mounted the screws into that. Placing it here allows for moving the tv around for viewing from just about everywhere in the trailer. I placed a couple hook mounts above and below the cabinet door to help secure the tv with a strap when hauling the trailer. It has worked great for us. Here a some pictures. If you have any questions let me know.
- 2x4 inside of cabinet across from a/c plug.
- FCE32DC7-DE3C-41B6-BDD1-2678F7BBD97C.jpeg (19.45 KiB) Viewed 5744 times
- Mounting bracket screwed into 2x4 behind cabinet face.
- A08E89FB-9FB0-45C5-A410-6F934D532E20.jpeg (22.67 KiB) Viewed 5744 times
- Secured for travel with strap and cardboard cover.
- ADAEC8C0-44E0-4E3F-A96D-3FEAA5A1384E.jpeg (15.26 KiB) Viewed 5744 times
Re: TV mount?
Hey fundamental. Did you ever get an answer or install your tv mount yet? If not I installed on in my 15RB and works great. I can show you where we did it if you like.
Dscan
Dscan
Re: TV mount?
Wow, I'm surprised that no one seems to have a solution to this question!
TV mount?
My wife wants me to install a multi direction tv mount in our 2016 StarCraft AR one 15rb any suggestions on the correct way to go about this? I know the walls are not very thick so I have to be careful of that. Any recommendations on this would be greatly appreciated .
