solar panel wires
tcbro
Re: solar panel wires
Post by tcbro » June 18th, 2018, 7:13 pm
Thanks for the replies.
Yes, I have the Zamp receptacle but I'm looking for a permanent mount
I was looking at that plumbing vent and figure that's where I was going through. Panels are ordered and I'll let you know how I make out.
Tom
2016 AR-One 17TH
2009 GMC Sierra
Post by kuba122 » June 17th, 2018, 11:09 am
I used a vent for the plumbing... drilled it, ran cable to the roof, sealed it up with plumbers goop. I also used direct burial/waterproof cable.
Post by GaryG » June 16th, 2018, 2:44 pm
My 2016 26bhs launch has the solar receptacle on the outside of the trailer. I'm sure you have already checked for that. If yours had it you could just run the wire direct into the receptacle. I assume you are using the solar panels to charge your house batteries? Please post when you decide what to do so others can learn from your hard work. Thanks for posting.
tcbro
solar panel wires
Post by tcbro » June 16th, 2018, 3:32 am
Any good ideas about how to get solar panel wires through the roof?
Tom
2016 AR-One 17TH
2009 GMC Sierra
