Bearing and Seals Numbers
Re: Bearing and Seals Numbers
There's not too many different bearings and seals out there. The easiest way is to remove a set and go by a tractor supply store. They have them in packaged kits ready to go. Modern auto parts stores have them but cannot find them if you don't have a matching make and model of a car that would use the same bearings. We have one Napa here that has an old coot working there. He can tell you what bearing and seal it is just by seeing it in your hand. Once you identify them, write the numbers down where you can have them if you need them again.
I have a 1999 Starcraft Starflyer and wondered if anyone has the numbers for the wheel hub seals and bearings?
