TV Mount in Launch 16RB
Re: TV Mount in Launch 16RB
And a link to the mount I used, from Amazon.
https://www.amazon.com/gp/product/B0088 ... UTF8&psc=1
And inside the cabinet... just used a long enough screw, a few washers and a lock nut. Pulled the radio out below to mount the bottom screw.
- tvmount3.jpg (64.65 KiB) Viewed 3152 times
Here's a few more shots of mine, in hopes that it will help someone in the future.
- tvmount2.jpg (68.45 KiB) Viewed 3154 times
There was a motorhome storage facility fire in my neighborhood about a month ago, or so. Sorry you went through that. Glad you got a starcraft and really glad you figured out the TV mount!!
Hmm... they must have changed that for 2017. Our 2016 didn't have any specified location for a mount. I talked to Starcraft via e-mail and they said set it on top of the fridge.
I ended up putting the mount at the cubby up and to the right of the sitcker, kind of where the radio is. Here's a pic... sorry, only one I have was taken at night.
If that sticker says this is the location for the TV mount, you should be good to go. An email to Starcraft may also help. They sent us a measured drawing of the rear of our coach for us to install a ladder.
Just picked up a 2017 Launch 16RB hybrid after our motorhome was involved in a storage facility fire. In trying to get it usable we wanted to install a TV mount. There is a spot on the right sidewall of the refrigerator with a sticker for mounting location. It's a bit to the right of the thermostat.
Unfortunately, when I tap on it, the hollow sound leads me to believe there is no support behind that thin sheet of wallboard. Has anyone put a TV bracket in that spot? Did you have to pull the fridge to place some wooden support behind where the bracket would go? I don't want to tear up the unit before we even get to use it once.
Here is a photo of the location in question.
Users browsing this forum: Bing [Bot] and 8 guests
