Torx T20 8 point? Need help!
Re: Torx T20 8 point? Need help!
Try a #2 square bit. That should work.
Update, the #2 square drive bit worked perfectly! Project is completed!
Try a #2 square drive it should work
I've found that a #2 square bit fits! I'll get back on the project tomorrow.
Hopefully, problem solved!
I'm working on a project on my TT and the screws that I need to remove appear to be Torx T20 type but instead of the normal 6 points, these things have 8 points. WEIRD!
I've checked my local sources for a bit or screwdriver and come up empty. I've also looked on the internet and had no luck there either.
Is there another name for this fastener other than Torx? Has anybody found a bit or screwdriver to fit these screws?
I really don't want to drill them out.
Any help would be appreciated.
Pawpaw
Pawpaw
