Drain hoses on front undercarriage
heebzman
Re: Drain hoses on front undercarriage
Post by heebzman » August 24th, 2015, 12:22 pm
Those are the low point drains. The handles to pull to drain are located under the bench seat inside the trailer, usually right next to the water pump.
Post by jcarlilesiu » August 17th, 2015, 1:13 am
Those look like over flow drains to me.
If I over fill my fresh water tank, it will start to over flow from the bottom.
I don't think they are low point drains as there aren't any valves, but maybe they are located inside.
Post by moallen » August 15th, 2015, 3:43 pm
Look like low point drains. Maybe the valves are inside the trailer directly above them? Might be behind a panel?
tjcouch
Post by tjcouch » August 14th, 2015, 9:59 pm
On the AR-ONE 14 RB:
I have looked through the manual, but can not seem to find a reference to these two, what I assume to be, drain hoses. (pictured)
Can anyone enlighten me? (water heater pop off? refer condensate drain?)
