StarCraft Homestead 26'
Discuss the Travel Star line of trailers, everything you have ever wanted.
garystell
Re: StarCraft Homestead 26'
Post by garystell » January 30th, 2018, 2:34 am
kuba122 wrote:
January 27th, 2018, 11:36 am
I’ve never removed a furnace,but, I have had it apart to use the soace to run cables through. There were 8 screws holding the unit and faceplate in, then fuel line and electrical and thermostat wire to remove, then I think it will pull right out. If you find anything confusing, post up a photo and We’ll help as much as we can.
[/Thanks so much for your reply. I did manage to get it out, it wasn't quite as difficult as I anticipated.
garystell
Post by garystell » January 30th, 2018, 2:32 am
Never mind, I have removed the heater!
Post by kuba122 » January 27th, 2018, 11:36 am
garystell
Post by garystell » January 24th, 2018, 11:08 pm
I need to remove my heater/furnace from underneath my fridge. Is there an easy way to do it? Are there anythings I should know about removing it?
I also would appreciate some info on the wiring of the refrigerator/freezer. It seems some rodents had a party on my wiring!
Thanks,
Gary Stell
