Thank you so very much for the information and suggestions. I think we have the hot water figured out and will be getting weight distribution bars...
Everyone stay safe!!
2011 19BH water heater and sway bars
- Site Admin
Re: 2011 19BH water heater and sway bars
Sway Bars .... there may be no "need" for weight distribution or sway bars. There may possibly be a want. There are some possible technical reasons they may be required, but, if the trailer is within your vehicle's towing specs .... sway bar/weight distribution is not an absolute necessity. I use weight distribution, just because it makes things feel better (especially in cross winds and curvy roads). It also helps with the stance of your tow vehicle. Although, I went with stiffer rear springs AND weight distribution.
I would definitely recommend it.
- Site Admin
When you turn on the water heater, there is an auto sparker that lights the propane. At least that's the way it has been for the past 7 or 8 years. You might try and find the brand/model of your heater and do a quick google search for a youtube video or even call the water heater manufacturer. Trailer paperwork rarely has a lot of useful information on these accessories. Good Luck, let us know if you have any other questions!
Hi,
Can anyone tell me if there is a switch inside to light the hot water heater or do we have to light the pilot light outside?
The trailer we are looking at does not have a place on the hitch for sway bars. The current owner (we are thinking of buying it) said we don’t need sway bars. We live in Canada. It is a tandem axle.
I can’t find a manual to read up on how to operate everything in the trailer.
Users browsing this forum: No registered users and 6 guests
