Water pump won’t shut off -switch at panel off
Mispecial
Re: Water pump won’t shut off -switch at panel off
Post by Mispecial » October 23rd, 2019, 9:43 pm
It was actually a 2nd switch, on the rear exterior. I didn’t know I had one. Somehow it was turned on.
Post by uct » October 22nd, 2019, 11:14 pm
Bad switch
Post by kuba122 » October 21st, 2019, 2:05 pm
That goes against logic .... the switch should cut power to the pump . Clearly that isn’t happening. Probably will need some troubleshooting and electrical work done. That’s my guess.
Mispecial
Post by Mispecial » October 20th, 2019, 6:15 pm
Hello,
I winterized my 289BHS today. And my water pump is running with the switch at the monitor panel off. If I pull the fuse it will shut off.
I drained the fresh water and water heater tanks. Used the pump to siphon rv antifreeze and ran all taps (hot and cold) untill antifreeze flowed through. Shut all taps, turned off the switch and could still hear the pump running. Any ideas?
