Tv installation
waynescott5150
Re: Tv installation
Post by waynescott5150 » January 3rd, 2020, 2:37 pm
This is how we did ours (see attachments) This tv mount I have more info on of needed. It swivels a little over 180 degrees if we need it to. Just an idea if needed...
tv mnt 1.jpg (120.39 KiB) Viewed 6713 times
tv mnt 2.jpg (111.23 KiB) Viewed 6713 times
Ferrenburg
Re: Tv installation
Post by Ferrenburg » October 19th, 2019, 10:34 pm
We have a 2018 SC 18QB and installed a TV mount and 24" TV. It installed really easily. I highly recommend you run a pilot hole in the wall stud and use a thicker/short screw to hold the Mount to the wall with max grip. :)
Here are the parts we got from Amazon to do the job:
$17 - VideoSecu TV Wall Mount Monitor Bracket with Full Motion Articulating Tilt Arm 15" Extension with VESA 200x200 ML14B WS2
$122 - LG Electronics 24LH4830-PU 24-Inch Smart LED TV (2016 Model)
These two work well for us.
Jim & Tammy Ferrenburg
2015 Nissan Frontier Pro-4X
2018 Autumn Ridge 18QB Extreme Edition
Re: Tv installation
Post by cattzap » June 3rd, 2019, 3:38 pm
Just knock on the wall where you want to install it. You'll feel and hear where the studs are.
Lovelandmimi
Re: Tv installation
Post by Lovelandmimi » April 19th, 2019, 3:26 am
My son installed a 24 inch tv using an RV mount from Amazon. It’s on the wall at the end of the bed next to exit door. Worked great!
bbjr1964
Re: Tv installation
Post by bbjr1964 » April 13th, 2019, 2:07 pm
Hi I just bought a 19bh and was wondering the same thing. Did you figure out a good size and place for your TV ?
Brad
Lovelandmimi
Tv installation
Post by Lovelandmimi » June 19th, 2018, 4:18 pm
Just purchased the 19bh and want to install small tv on wall at end of bed. I got the plans from Starcraft that showed that there are 2 x 4’s in the wall. Where did you install your tv?
