Tv installation
- waynescott5150
Re: Tv installation
This is how we did ours (see attachments) This tv mount I have more info on of needed. It swivels a little over 180 degrees if we need it to. Just an idea if needed...
- Ferrenburg
Re: Tv installation
We have a 2018 SC 18QB and installed a TV mount and 24" TV. It installed really easily. I highly recommend you run a pilot hole in the wall stud and use a thicker/short screw to hold the Mount to the wall with max grip.
Here are the parts we got from Amazon to do the job:
$17 - VideoSecu TV Wall Mount Monitor Bracket with Full Motion Articulating Tilt Arm 15" Extension with VESA 200x200 ML14B WS2
$122 - LG Electronics 24LH4830-PU 24-Inch Smart LED TV (2016 Model)
These two work well for us.
Jim & Tammy Ferrenburg
2015 Nissan Frontier Pro-4X
2018 Autumn Ridge 18QB Extreme Edition
Re: Tv installation
Just knock on the wall where you want to install it. You'll feel and hear where the studs are.
Re: Tv installation
My son installed a 24 inch tv using an RV mount from Amazon. It’s on the wall at the end of the bed next to exit door. Worked great!
Re: Tv installation
Hi I just bought a 19bh and was wondering the same thing. Did you figure out a good size and place for your TV ?
Brad
Brad
Tv installation
Just purchased the 19bh and want to install small tv on wall at end of bed. I got the plans from Starcraft that showed that there are 2 x 4’s in the wall. Where did you install your tv?
