Re: Shower leak
Posted: June 18th, 2020, 9:13 am
by kuba122
JohnZig wrote: ↑May 12th, 2019, 5:49 pm
Our 2018 24RLS p trap was completely disconnected from the factory, the connectors that they use on the bottom of the shower drain are very cheap. Not a fun repair due to limited space under shower access. Our shower also leaked from the glass shower door track where it meets the walls, little caulk inside the track took care of it. I have some pictures of the repair if it turns out your trap is leaking and you would like to see what we did.
I think we are hoping you still have pictures .... I never had to do a p-trap repair.
I really hope you get you your leak fixed.
Re: Shower leak
Posted: June 17th, 2020, 3:41 pm
by Gafiremedic1
kuba122 wrote: ↑May 11th, 2019, 1:26 pm
I thought I had a shower leak at one time. Water under the trailer in the liner. I looked everywhere. I never found a leak. Opened the liner, dried it out, resealed. Never saw water in there, again. I may never figure out how it got in there, to begin with. Good luck!!! Hope it’s not too difficult to deal with!
could you send me the pics of the pea trap repair?
gafiremedic1@gmail.com thank you.
Re: Shower leak
Posted: May 12th, 2019, 11:12 pm
by JohnZig
Sounds like the same place as ours, it leaked down the wall when the bottom track filled with enough water and the camper sitting just right. Found the leak with a flashlight looking in the track next to the wall, no sealant at all by wall on either side.
Re: Shower leak
Posted: May 12th, 2019, 8:47 pm
by uct
Thanks finally found the leak. How to fix not sure. Seems to be coming from the corner of where the door meets the wall at the bottom
Re: Shower leak
Posted: May 12th, 2019, 5:49 pm
by JohnZig
Re: Shower leak
Posted: May 11th, 2019, 1:26 pm
by kuba122
Shower leak
Posted: May 10th, 2019, 12:44 pm
by uct
Shower has a leak. 24rls looked at re valve from behind the TV acess panel. No leak. Will check the p trap today. Any help is welcome tks
