Re: Solar Panel battery charging
Posted: July 13th, 2021, 9:26 am
Firstly we should know the basics of the solar. So to know the basics of the solar check out this guide which provides complete information.
Information for owners of Starcraft and other brands of RV
https://starcraftowners.com/
Thanks for your response to my solar panel post. I appreciate the added info about the furnace running at night. I will watch this carefully. I am a bit confused as to why, when hooking up the trailer to the tow vehicle that you would be worried about sufficient power for the electric brakes? Does the trailer's brakes not get their power from the tow vehicle's battery and not the trailer's batteries? I would not have the tow vehicle hooked up to my trailer when boondocking either.Sbrinson wrote: ↑March 6th, 2017, 5:34 pmHi Guys, I started using solar panels to top up batteries several years ago when I started using a travel trailer at our hunting camp, which is way off the grid. I mounted two 15 watt solar panels & controller on a frame made from 3/4" PVC pipe. The frame can be manually moved, and the angle of the panels can be adjusted for maximum sun exposure. At the time my Coachmen trailer did not have a battery shut-off switch, and I eventually discovered that the propane detector put a constant load on the battery that was sufficient to pull the battery down over a couple of weeks. I installed a marine-type battery selector/shutoff switch and used it to select which of two deep-cycle batteries would be powering the trailer and which would be charged by the solar panels....and to disconnect both from the trailer whenever it was sitting unused. You may already know this, but it is important to recognize that batteries connected in parallel (+ to +, - to -) will equalize so that they both have the same potential. This means having a fully-charged battery connected to a weak battery will result in the weak battery draining the strong battery. Consequently it is a good idea to have some method of separating them. Both batteries are in cases, and each one is connected to the switch with a 4ft. long pigtail utilizing a 7-pin trailer-type connector. This arrangement lets me put a depleted battery in the back of my pickup and connect it to the vehicle's trailer connector to re-charge it off the vehicle's alternator when I'm driving around. I moved the whole shebang over to my Starcraft Launch 24RLS when I upgraded trailers. The Launch does have the external connection for the solar system input, but this still requires having a controller metering the charging. Starcraft also included a shut-off switch, which is located in the front pass-through storage compartment.
For off-the-grid survival, your 12-volt furnace blower is probably going to be your most serious power consumer. If you are in extremely cold weather, low battery power will result in the blower starting-up... but the furnace's safety system will not allow ignition of the burner. If you are already asleep, the blower may run all night, causing further depletion of the battery. Important notice: As you experiment with whatever solar hookup you eventually decide to use, make certain before towing that power to the trailer's electric brakes has not been compromised. A small Volt-Ohm meter is a great item to include in your trailer toolkit.
Thanks for your response to my post. If you are referring to the controller as 'anything more' some solar panels do not come with a controller, that is the reason I had to purchase one, otherwise, without a controller or regulator, the solar panel can possibly damage your battery because the 15 watt solar panel can generate as much as 22-24 watts at peak sunlight and that, over an extended amount of time can overcharge and ruin your 12 volt battery or even worse, melt wires, etc.KirkB wrote: ↑March 6th, 2017, 3:35 pmHi Gary. It seems like we are both starting our new trailer adventures at the same time. I drive from Burbank CA to Phoenix on Wednesday to pick up my new 19BHS. Will be towing with a 2016 Toyota Highlander. Will be interested in hearing how the solar panel works out. I have a question though. My understanding is that there trailers are "solar ready". Why do you (we) need anything more than just the panel and the attachments that come with it?
