Hi
I have poor radio reception in my 04 WRX. I believe the antenna is hidden in the rear window glass.
I did a search and it appears that this can happen if your headunit antenna power cable isnt plugged in.. Turns out my headunit Pioneer does not have this cable. Only the input for the main antenna.
Rear window is also tinted, which I dont think helps.
Wondering if anyone has had the same problem and had any success in boosting the signal?
Radio antenna, very poor reception
Re: Radio antenna, very poor reception
I changed the factory radio and noticed the splitter and most connections from the digital roof antenna were loose.Using the TV amplifier helps some.
Will upgrade the speakers next.
2017 Silverado
Where has Starcraft hidden the radio antenna? My radio gets very poor, nearly no stations anywhere I have been, including sitting in my yard. I did find the radio antenna wire in the space above the radio had not been plugged in, but after plugging it in it was now better. If it is internal with the TV antenna, how can a digital TV signal and an FM radio share the same antenna?
2016 Launch Ultralight 21FBS
