Low Point Valves (2015 Launch 26bhs)
VictorH
Re: Low Point Valves (2015 Launch 26bhs)
Post by VictorH » October 5th, 2017, 7:57 pm
The quarter turn also works but removing the metal pins allows air to enter more quickly. Another thing that I was hoping to avoid by pulling the pins and not just turning the valve is to avoid fatigue on the flimsy plastic valves. I am worried that too many turns will result in the valves either cracking or not sealing properly. Wow, who knew I had so much to say about low point drain valves...
Victor and Leslie
2015 StarCraft Launch 26 BHS and 2005 Toyota Sequoia
dheasman
Post by dheasman » October 5th, 2017, 2:41 pm
Thanks Victor!
Post by Houston Remodeler » October 5th, 2017, 12:30 pm
Pins out? I just give them one quarter turn ? There feels like an internal click...... Have I been doing this wrong?
VictorH
Post by VictorH » October 5th, 2017, 4:25 am
Yes, the low point drain valves are behind a panel below the sink (I have the same model). Warning, put some towels around the valves before gently pulling the pins out horizontally (otherwise you will be mopping up a mess of water since it will likely have some residual pressure).
Victor and Leslie
dheasman
Post by dheasman » October 4th, 2017, 9:47 pm
Ok thanks, will take a look. Sounds convenient?! (Hopefully you are catching my sarcasm, haha)
Post by moallen » October 4th, 2017, 10:48 am
The valves are probably right above those stubs inside the trailer. I have to take the lower panel off my bathroom sink to get to them on my 24rls. You'll want to make sure that end of your trailer is lower. But just to make things complicated, then I have to raise that end to get all the water to drain out of my fresh water tank which is on the other end.
dheasman
Post by dheasman » October 4th, 2017, 2:56 am
I have simply never looked for the fresh water low point drain valves, but with a cold snap on us, can't seem to find them. I see the sticker on the outside of the trailer, but there are just two stub tubes sticking through the floor. Looked all around inside and have no idea. The manual didn't provide much help either. I was hoping it would be as easy as the low point valve for the water tank release, I was wrong! If anyone can point me in the right direction that would be great.
