Ran into my first problem with my brand-new 26BHS when I got it home... Sat on the couch, and when I went to get up from it (this with the slide pulled in, which has the couch on it), I pushed down on the sidearm to help myself up, and it snapped right off the wall! No wonder - the back of the sidearm is only 1/8" plywood, and was attached to the wall with three screws through the back.
You can see in the second pic where the screw holes are, and also see how thin the wood is (the back is the same thisckness as the sides and bottom, which you can see in the pic)
So my thoughts are:
1) If I am going to re-attach the sidearms, I will install two "L" brackets on the slide out wall where the sidearms attach (pic 1) and glue a thicker piece of wood on the bottom on the sidearm assembly, which I will then attach to the protruding "L" brackets. Hopefully this would allow for quite a bit of downward pressure on the arm.
2) On the other hand, I could just lose the sidearms, and if I could get a piece of the molding that goes from the top of the slideout to the top on the sidearm, on the face of the slideout, then I'd just patch the exposed wood where the sidearm attached to the wall with that. Does anyone have any experience getting wood/moldings/etc from Starcraft to do such patches? Or do I go thru the dealer?
Wish things were built just a bit better (heavier materials) but I guess that's the price to pay for such a lightweight TT...
- Will
