My sad tale and help needed
Re: My sad tale and help needed
Post by moallen » May 26th, 2016, 12:02 am
Something else to keep in mind that I found out the hard way is the power line to the electric brakes doesn't go through the on/off switch. It connects directly to the battery, just like the power jack, at least on my 24rls. So, if you accidentally unplug the breakaway switch by stepping on the cable like I did, it will run the battery down in about 3 hours.
Post by uct » May 25th, 2016, 10:22 pm
When I got my 24lrs home I noticed the wire from the electric JACK to the 30 amp fuse was pinched between the frame and my w/d hitch brackets that the dealer installed from my previous trailer. This year the electric JACK would not work. Fuse was good but fuse holder and fuse blades were corroded. Cleaned both and use dielectric grease and all is fine
Scouser1953
Post by Scouser1953 » May 25th, 2016, 9:24 pm
Did you solve your problem? I'm having the same problem after I connected my battery after winter storage. Found the 30 amp fuse had also blown.
Tongue jack doesn't work unless I connect to the tow vehicle with the engine running.
GaLobo
Post by GaLobo » July 28th, 2015, 1:11 am
Not sure how the TV cable could have caused your problem. It is my understanding the TV when hooked up only charges the battery and runs the running lights on the trailer. Connect to shore power and then start trouble shooting. Good luck and keep us up to date.
Post by jcarlilesiu » March 27th, 2015, 4:18 am
The trailer lights are on a completely different circuit than the 12V system.
Though the trailer lights are run from a 12V system, its power is provided from the TV.
It sounds like you are having a problem getting power to the circuit board and running anything on the battery.
Question is... what happens when you plug into shore power? Does the converter/charger blower turn on?
mcmahonm
Post by mcmahonm » March 23rd, 2015, 10:54 pm
You say the trailer lights are working, but no internal lights. Is the trailer plugged into house or garage or are you using the battery? can you confirm the battery is charged?
If the trailer lights work when connected to the tow vehicle than the cable you severed is fixed. The 30 Amp fuse should be check very closely I had one go that looked okay but was not.
turn off all the breakers and work your way through them to back on. I not sure what the panel look like on this trailer my 278BHS is still in storage.
Did you disconnect the battery while you were doing the repair?
2013 Chevy Silverado Z71 & 2012 Autumn Ridge 278BH
http://files.michaelmcmahon.org/VisitedStatesMap.jpg
tigerbaywarrior
Post by tigerbaywarrior » March 23rd, 2015, 2:12 pm
rbrent wrote:Does the 110 volts stuff work? I don't know which launch you have but there is a battery cutoff inside my front cross thru storage compartment that someone may have turned off when you picked it up. Just trying to help!
Thanks!
Yeah I have that cutoff. ...already checked that one. :(
It's a 28BHS ultra lite.
rbrent
Post by rbrent » March 23rd, 2015, 1:33 am
Bob and Margaret
2015 Launch Ultra Light 24RLS
Westland, Michigan
tigerbaywarrior
Post by tigerbaywarrior » March 22nd, 2015, 10:05 pm
I need some help....
We bought a new Starcraft Launch 2 weeks ago. Drove it home from the dealers and managed to sever the electrical cable connecting the trailer to the SUV when reversing (it was WAY too long...).
Ordered a new slightly shorter cable. Installed the cable and found that no internal electrics were working. Looked at the 30 amp wire fuse from the battery and found that had blown (I suspected shorted when the cable severed). Replaced the fuse and now NOTHING works! I can't use the electric tongue jack or anything internal.
I've tried the GFI. I've checked the breakers. I rechecked the fuses.
Is there a small button I've missed somewhere?? I know on our previous trailer, there was a really small button you had to press underneath that reset the circuit.....
I checked the brake lights and blinkers - they work.
I'm calling the dealer tomorrow and I'll probably be back there next week unless somebody has any ideas.
Thanks!
Users browsing this forum: No registered users and 22 guests
