grey water tank level indiicator
jjvirginia@gmail.com
Post by jjvirginia@gmail.com » September 28th, 2016, 12:55 am
Add 1 cup Cascade and 1 cup of TSP to 5 gallons of hot water b4 your next trip, pour it in, drive then empty.
Re: grey water tank level indiicator
Post by Houston Remodeler » June 15th, 2016, 9:10 pm
Before doing anything I'd pour 5 gallons of water with a cup of water softener and a squirt of dishwashing liquid into the tank and let it slosh around during the drive to the next campsite. If you drive like I do, the sloshing will be very effective.
The water softener and sloshing will help dissolve and loosen any debris in the tank. Flush well, then look at the sensor again.
Then I'd go chasing wire faults. Tank sensors are notoriously wrong.
tslarson
Post by tslarson » June 7th, 2016, 10:06 am
It sounds to me like you have the exact opposite problem most others have. Your's shows empty when filled. Dirty sensors will generally show the opposite, full when empty. I suspect a problem with the sensor wiring or monitor panel itself.
2009 Ford F150 CC FX4
Post by jcarlilesiu » June 4th, 2016, 4:18 am
It's more typical to see this in black tanks sooner than grey. Regardless, usually flashing the tank repeatedly will eventually free the sensor up. They do make a product for censor cleaning that you can add to the tank and it will help flush out any debris.
These sensors are notoriously inaccurate and stuck as you are describing.
jmetzke1
Post by jmetzke1 » June 2nd, 2016, 4:09 pm
We have a 2016 Launch 26RLS. After only a couple uses the grey water tank level indicator does not work. Only shows E even though I have filled it several times to check it. Is there something I can do to try to fix this?
Users browsing this forum: No registered users and 27 guests
