2016 24 rls. Br tv
Re: 2016 24 rls. Br tv
Yes that is what I used. I do not have the 20 inch TV on the Mount when traveling.
Do you think this length will work on the side wall 1/4 x 3/4 long
I used 1/4" x 1 1/4" lag bolts. There happened to be a wood "stud" right where I wanted to mount the bracket. The bracket I used needed 2 lag bolts spaced about 5" apart vertically in line with each other. My bracket was about 2" wide and 8" tall.msmith wrote:Moallen, I was looking at the lag bolts you used on your TV installation, not sure what length would be a good fit for the side wall. I'm thinking 3/4 to 1 inch, any thoughts out there?
I suspect the laminated exterior wall is not as thick as the interior wall I used, so you might want to only use 1" lag bolts or do more checking.
Starcraft files for bankruptcy in 1990; Jayco bought them shortly afterwards. Starcraft operates as a subsidiary of Jayco.msmith wrote:I see that the drawing says it is 3 & 1/4 down from ceiling how car from bathroom wall? Also diagram says Jayco do they make StarCraft? Thanks
1999 Starflyer PUP
2003 GMC Envoy 6 cylinder
Any response from Customer support on how to get these drawings for other models?
If you look at the drawing the center of the mounting block is about even with the rear edge of the window, The block is about 11 x11 inches, I think jayco owns starcraft
I left a message for Starcraft asking where to mount the TV and they sent me the drawing. Excellent service!
Users browsing this forum: No registered users and 26 guests
