Slideout Controller
msmith
Re: Slideout Controller
Post by msmith » October 20th, 2015, 10:27 pm
Hi, can you tell me where to manually operation is for the slide and awning is. Thanks, msmith
Post by Houston Remodeler » October 16th, 2015, 2:58 am
It took a while to find the one connection that wasn't plugged in male to female all the way. Once we plugged it in properly, taped it properly, and secured it properly we made the 5000 mile trip with no problems.
Post by moallen » October 15th, 2015, 10:04 pm
You've got me curious now! Did it bind up going out or coming in? Once I extended mine when the trailer wasn't level, and it sounded like it wasn't too happy. So far, I haven't had a problem with it.
Post by Houston Remodeler » October 15th, 2015, 7:59 pm
I thought we had seen every square inch of our TT until the slide out stopped working the morning we were to leave on our 5 week trip.
Lippert told me to look for the controller. Took me an hour to find it. Ours is in the same spot.
Sure enough, the codes told me what needed to be done.
Post by uct » October 13th, 2015, 10:55 pm
Thanks. I saw that when I fixed the furnace mounting. Had no idea what it was for.
Slideout Controller
Post by moallen » October 13th, 2015, 6:39 pm
It's a good idea to know where your slideout controller is located in case the slideout jams. The controller has status code leds and a reset, as well as cables that will need to be unplugged for manual operation. I stumbled across mine while checking my furnace for a recall. It's on the floor right beside the furnace on my 2016 24rls.
While I was at it, I also made sure I had the right size sockets to manually operate the electric tongue jack and awning.
