2016 AR one 15 rb front window leak
Discuss entry level campers offer a host of amenities at a low cost and are easily towed.
Re: 2016 AR one 15 rb front window leak
Post by kuba122 » August 27th, 2020, 10:31 pm
That window leak was a fairly common problem. They do make a caulk remover. I redid mine within the first year. I looked up how to do it on youtube videos. Youtube is like a little how to university! :D
jack69
Post by jack69 » August 25th, 2020, 12:29 pm
I notice when we bought this trailer a week ago, everything on this trailer looked brand new EXCEPT for the sloppy caulking on the front window. It's obvious that that was a problem on this trailer. I'll be watching it closely. Is there a way to "trim" the caulking thats uneven all around the window?
Fundamental
Post by Fundamental » June 26th, 2020, 2:22 pm
kuba122 wrote:
June 13th, 2020, 9:51 am
That was a recall item, I believe. You can remove the old caulk and replace with new. It’s not hard to find you tube videos explaining the process. I would recommend you find out if that item is still under recall and have a tech fix it.
No, their is no recall on this unit. I'm out of warranty so they won't touch it!
:D
Fundamental
Post by Fundamental » June 24th, 2020, 8:53 pm
Thanks kuba I will check into it. Never even thought about a recall
:D
Post by kuba122 » June 13th, 2020, 9:51 am
Fundamental
Post by Fundamental » May 25th, 2020, 6:51 pm
:? The front window of my AR one 15 RB leaks at bottom left when you face the front of camper. Looks as tho the gasket is shrinking away from its self at the seem, is their anything that I can do my self to fix such a problem? Any help from the pros would be greatly appreciated! 😩😫
:D
