Generator box for Honda 3000
Re: Generator box for Honda 3000
Post by Houston Remodeler » April 23rd, 2016, 2:33 am
temperatures recorded on an 85 degree day
https://youtu.be/AeDKHAT2FeA
001
Post by 001 » April 22nd, 2016, 11:44 am
Very nice
Post by Houston Remodeler » April 22nd, 2016, 1:17 am
As requested, a video of the genny in operation with temperatures recorded
https://youtu.be/O10y76tGs1w
Post by Houston Remodeler » April 20th, 2016, 12:18 am
The bolt holding the genny down is 1/2 inches
The hole the bolt goes through the truck bed is 2 3/8 inches
To keep the genny from sliding around and working loose, the wood plugs keeps the bolt, and the genny centered over the 5th wheel hole.
Post by uct » April 19th, 2016, 11:58 pm
Houston Remodeler wrote:upper wood plug detail
The bottom 1.5" has the full sized hole for the female nut. The upper section has room for only the carriage bolt. The sections are screwed together to allow everything to be taken apart when the genny goes in for repair.
Please explain the purpose of the wood plugs. Looks good
Post by Houston Remodeler » April 19th, 2016, 7:06 pm
I'll load it into the back of the truck later this week when temps get over 80ºF for a trial run. I'm concerned about the genny overheating, so I'll use my temperature ray gun to check the operating temps as it idles with the eco throttle off.
001
Post by 001 » April 19th, 2016, 3:14 pm
Houston Remodeler wrote:Yes I can, what would you like to see ?
The operation of it.
Post by Houston Remodeler » April 19th, 2016, 1:53 pm
001
Post by 001 » April 19th, 2016, 3:13 am
Can you make video?
Post by Houston Remodeler » April 19th, 2016, 2:42 am
to plug the generator into the TT, an inlet box was purchased (as noted above) along with the cord. The box is mounted to the front of the TT, a wire sent back to the rotary switch.
generator inlet open smaller.jpg (34.37 KiB) Viewed 4116 times
