AC/Furnace Thermostat Mod
Re: AC/Furnace Thermostat Mod
Read the digital themostat thread, I used a honewell 5/2 .Easy mod. You will loose either high or low speed. I chose to loose low.
I have been thinking the same with a larger temperature read out screen.
Got a thermostat to reccommend ?
Sorry that I can't help you with you question.
Pretty sure that my camper came with the setup like you are wanting to do. What setup do you have now?
I have been researching doing this mod....Its when you replace the gas furnace thermostat with a home type one and connect it to the AC system...so you can control your furnace and AC like you do at home....it will also turn off the AC & Noisy Fan when the temp is reached just like at home (Mostly why I want this). Just was curious if anyone has done this MOD? I have read a few different guides on different sites...just wanted some input.
Here is the mod....
http://www.fiberglassrv.com/forums/f56/ ... 24914.html
Thanks!
Here is the mod....
Thanks!
