corner post problem
Discussion for all discontinued or other model RVs. Don't own a Starcraft? That's ok, we'll let you sit around the fire too.
dstrom
corner post problem
Post by dstrom » April 10th, 2022, 10:16 pm
Hello and thanks in advance for any help and or suggestions in resolving this problem. We have a 2003 Starcraft Centennial 3606, only been camping with it a few times. While at home we were replacing the flooring and I noticed a corner post safety pin was almost out (It didn't have a cotter pin). I went to put it back in, however, the pin came out altogether, the corner (the posts disappeared inside) dropped and the spring came popping out ( still attached in the tube). I have the directions from Goshlin on who to replace the spring, the spring is fine. Just have to attach it to the posts. Should I take out the spring altogether and then follow the directions from Goshin, or is there a simpler way to attach it to the post? The camper top is being propped in that corner up with a 2x4 for now.
Thanks again for any help
Dave
Users browsing this forum: No registered users and 23 guests
