Thanks for the update!CenOhio wrote:Pawpaw: Just finished my second outing using them and I'm a fan for sure. I can think of one campground I've visited in the past where this might not give me enough lift all by themselves so I might keep carrying a board or two just in case. But, so far they are awesome and I can recommend them with the one small question about durability I mentioned before. Time will tell.pawpaw wrote:I've been thinking about getting a pair, and I think I'm going to order them for my 329BHU. I'm surprised that it had to be trimmed, but it doesn't seem to be a major problem.CenOhio wrote:Update: I finally was able to get out to the trailer and test fit, sure enough I had to cut off about 3 inches to get it to fit properly between the wheels on my 329BHU. This was about a five minute job with a hacksaw. Next up: The first real life test next weekend on our first outing of the year (finally!)
Anderson Levelers anybody?
Re: Anderson Levelers anybody?
2014 Autumn Ridge 329BHU.
Places we've camped...
Well, first trip out for the season is in the books! Yay!!! Left a little early on Sunday to avoid the bad weather.
These Levelers worked exactly as advertised. It was sooooo nice to just back up till I was level. I think I maybe should have trimmed them both down and not just one of the pair, because I needed to get off of them by pulling back forward (opposite the way I got on them) to avoid having the untrimmed one end up getting stuck between the two tires.
Other impressions: It's going to be interesting to see how they hold up to use. I ended up with a pretty decent gouge in one from a piece of small gravel that was stuck underneath. Maybe that was operator error!
Still, so far, so good. I like them. Now I'm just hoping that they last.
Very cool. Let us know how they work out, and share your outing when you get a chance.CenOhio wrote:Update: I finally was able to get out to the trailer and test fit, sure enough I had to cut off about 3 inches to get it to fit properly between the wheels on my 329BHU. This was about a five minute job with a hacksaw. Next up: The first real life test next weekend on our first outing of the year (finally!)
Ahh, just regular chokes.CenOhio wrote:Not sure I understand your question. One (or both) levelers would go under the low side wheel(s). On the high side you'd just chock the tires as normal. Front to back you are leveling with the tounge jack.jcarlilesiu wrote:Thanks!
I didn't have time to research, so thanks for the link.
The only question I have is how it handles two different sides. If the camper is on a site that is unlevel side to side, and you put those levelers on both sides, when you pull forward, won't the tires roll the same amount on each side of the trailer? If so, won't it still be unlevel?
Hope that clears it up. Sorry if I misunderstand and am stating the obvious.
Yeah, that makes sense. I was thinking you would have to use them on both sides.
I have the Anderson levelers and they are super easy to use, since i am on two axles i had to get a pair of them but super easy to use... Just figure out what side you need to come up on, slide them under the tires and either back up onto them or pull forward on them, and put the block in place once the bubble level is good. Takes me less than 5 minutes to get my rig level side to side....
2014 Starcraft TravelStar 239TBS
2012 Dodge Durango Citadel 5.7 Hemi
Users browsing this forum: No registered users and 18 guests
