Interference on TV when playing DVD, UNTIL I turn on 12v light
Re: Interference on TV when playing DVD, UNTIL I turn on 12v light
Thanks for the great info, kuba122! When I get an opportunity, I'll open up that space and check out the wiring.
2013 Starcraft Travel Star 229TB
2003 Chevrolet Suburban
Sounds like the DVD player doesn’t have a good ground. You’re probably going to have to open up that space to see rhe wiring. The black wire on the DVD should connect to a white RV wire .... you coud also connect the black DVD wire to any metal on your RV (frame metal).
Hi All,
First time post here. Thank you in advance for any information you might be able to provide! We have a 2013 Travel Star 229TB with a "continu-us" brand TV and a "SoundStorm Laboratories" in-dash DVD player, stereo, etc. The TV display is fine when watching broadcasts, but when watching DVD's the display becomes wavy. However, the wavy lines go away if I turn on the 12 volt dome light closest to the DVD player. I would almost expect the interference to occur when turning on the light, but it is actually just the opposite - it goes away when I turn on the light. Any ideas on how to fix? (other than leave the light on )
Thanks!
SteveZ
Thanks!
SteveZ
