Dvd radio
Re: Dvd radio
This is what I did to remove our Furrion 5600. You have to take the face trim off and carefully put one key in each slot on the sides as straight as you can. I actually sprayed a little WD forty into each side first to assist with the radio sliding out.
Re: Dvd radio
Got a hammer?uct wrote:No. Will not slide out
Re: Dvd radio
Re: Dvd radio
I found the release tools and inserted them in the slots but the unit will not slide out like I thought it would help
Re: Dvd radio
If the radio is single din like the one that's in mine there should be a din tool in the starcraft bag that has all the paperwork in it. Slide said tool on either side of unit and it releases the latches and radio slides rite out. Hope that helps.
2016 starcraft launch extreme 16rb 2007 toyota fj cruiser
Re: Dvd radio
Don't Owen one yet but there is a outside plate (frame) around on the radio that snaps off and will give you access to the release tabs to pull the radio out. Some need a u shaped tool to remove. I use to install them years ago hope this helps. PS OUTSIDE frame is fragile be careful !
Re: Dvd radio
I've wondered the same thing. Looks like the radio was installed as the cabinet was being built. I think a person would have to remove the inside wood panel to the right side of the radio. It should've had screws instead of staples or brads. Might be tricky getting the panel out without damaging it.
