2016 24 rls. Br tv
Re: 2016 24 rls. Br tv
Post by uct » March 16th, 2016, 7:37 pm
Yes that is what I used. I do not have the 20 inch TV on the Mount when traveling.
msmith
Post by msmith » March 16th, 2016, 3:12 am
Do you think this length will work on the side wall 1/4 x 3/4 long
Post by moallen » March 15th, 2016, 8:05 pm
msmith wrote:Moallen, I was looking at the lag bolts you used on your TV installation, not sure what length would be a good fit for :roll: the side wall. I'm thinking 3/4 to 1 inch, any thoughts out there?
I used 1/4" x 1 1/4" lag bolts. There happened to be a wood "stud" right where I wanted to mount the bracket. The bracket I used needed 2 lag bolts spaced about 5" apart vertically in line with each other. My bracket was about 2" wide and 8" tall.
I suspect the laminated exterior wall is not as thick as the interior wall I used, so you might want to only use 1" lag bolts or do more checking.
shawnrpg
Post by shawnrpg » March 15th, 2016, 11:03 am
msmith wrote:I see that the drawing says it is 3 & 1/4 down from ceiling how car from bathroom wall? Also diagram says Jayco do they make StarCraft? Thanks
Starcraft files for bankruptcy in 1990; Jayco bought them shortly afterwards. Starcraft operates as a subsidiary of Jayco.
1999 Starflyer PUP
2003 GMC Envoy 6 cylinder
msmith
Post by msmith » March 15th, 2016, 3:10 am
rwisema1
Post by rwisema1 » February 24th, 2016, 2:33 pm
Any response from Customer support on how to get these drawings for other models?
Post by uct » July 30th, 2015, 9:47 pm
If you look at the drawing the center of the mounting block is about even with the rear edge of the window, The block is about 11 x11 inches, I think jayco owns starcraft
msmith
Post by msmith » July 30th, 2015, 4:12 am
Dadof4
Post by Dadof4 » July 22nd, 2015, 1:59 am
I left a message for Starcraft asking where to mount the TV and they sent me the drawing. Excellent service!
Post by jcarlilesiu » July 22nd, 2015, 1:54 am
I will reach out to them and see if they can provide them. Or, if they are reading this site, they could just email them to the administrator. Hint hint.
Users browsing this forum: No registered users and 19 guests
