Post
by moallen » August 8th, 2015, 8:06 pm
If you just have 1 cable, then they must be using the yellow to send video from the player to the tv and the red/white is being used to send audio back from the tv to the player. You might have the red/white lines from the player plugged into the wrong jacks behind the tv. There are probably 2 sets of red/white rca jacks in the back of the tv. One set to send audio out, and one set to receive audio. You want the set labeled output to go to the player.
Some tv's have a 1/8" phone plug jack for audio out instead of rca jacks. If that's the case, you'll need an adapter cable to connect your red/white lines from the player. Did you say your tv came with a little adapter cable? What you need would have just red & white rca plugs, not one one with red, blue & green.
As far as 5100 mode, you just want it the way it powers up, which is radio, as long as no DVD is inserted. Mine can be playing the radio and as soon as I turn the TV on, it automatically plays the tv instead of the radio.
If I have the 5100 set to aux-in or a DVD inserted, mine won't play the tv.
