Dvd radio
GaLobo
Re: Dvd radio
Post by GaLobo » October 16th, 2015, 12:08 am
This is what I did to remove our Furrion 5600. You have to take the face trim off and carefully put one key in each slot on the sides as straight as you can. I actually sprayed a little WD forty into each side first to assist with the radio sliding out.
Re: Dvd radio
Post by jcarlilesiu » August 21st, 2015, 12:36 am
uct wrote:No. Will not slide out
Got a hammer?
Re: Dvd radio
Post by uct » August 20th, 2015, 10:21 pm
Post by jcarlilesiu » August 20th, 2015, 2:14 am
Ah, I know what kind you have now.
There are two tabs on each side of the radio mount that hold it in. When you slide the tool in through the side, out should flatten the tabs allowing the radio unit to slide out.
You can't get it?
Re: Dvd radio
Post by uct » August 17th, 2015, 2:58 pm
I found the release tools and inserted them in the slots but the unit will not slide out like I thought it would help
N7VDR
Re: Dvd radio
Post by N7VDR » August 16th, 2015, 3:24 pm
If the radio is single din like the one that's in mine there should be a din tool in the starcraft bag that has all the paperwork in it. Slide said tool on either side of unit and it releases the latches and radio slides rite out. Hope that helps.
Poofam
Re: Dvd radio
Post by Poofam » August 14th, 2015, 1:15 pm
Don't Owen one yet but there is a outside plate (frame) around on the radio that snaps off and will give you access to the release tabs to pull the radio out. Some need a u shaped tool to remove. I use to install them years ago hope this helps. PS OUTSIDE frame is fragile be careful !
Re: Dvd radio
Post by moallen » August 8th, 2015, 12:21 pm
I've wondered the same thing. Looks like the radio was installed as the cabinet was being built. I think a person would have to remove the inside wood panel to the right side of the radio. It should've had screws instead of staples or brads. Might be tricky getting the panel out without damaging it.
Dvd radio
Post by uct » August 7th, 2015, 8:24 pm
How do you remove dvd radio 2016 24 rls
